- Enable EAP globally or on the port.
Configure an I-SID offset value and enable I-SID offset globally on the switch:
Switch:1> enable Switch:1#config terminal Enter configuration commands, one per line. End with CNTL/Z. Switch:1(config)#eapol auto-isid-offset 1000 Switch:1(config)#eapol enable
View the current device configuration:
Switch:1>show eapol system
                                  Eapol System
                     eap : disabled
           Eapol Version : 3
         non-eap-pwd-fmt : mac-addr
     non-eap-pwd-fmt key : ******
 non-eap-pwd-fmt padding : disabled
 auto-isid-offset status : disabled
 auto-isid-offset value  : 1000
The following table defines parameters for the eapol auto-isid-offset command.
                             Variable  |
                             Value  |
                             <0-15995903>  |
                             Specifies the auto I-SID offset value. The default is 15995903.  |
                             enable  |
                             Enables auto I-SID offset. The default is disabled.  |
