Use the following procedure to display the SPBM Service Instance Identifier (I-SID) information. The SPBM B-MAC header includes an I-SID with a length of 24 bits. This I-SID can be used to identify and transmit any virtualized traffic in an encapsulated SPBM frame.
 - Select SPBM.
 - Select the I-SID tab.
I-SID Field Descriptions
Use the data in the following table to use the I-SID tab.
 Name  |
 Description  |
 SysId  |
 Indicates the system identifier.  |
 Vlan  |
 Indicates the B-VLAN where this I-SID was configured or discovered.  |
 Isid  |
 Indicates the IS-IS SPBM I-SID identifier.  |
 NickName  |
 Indicates the nickname of the node where this I-SID was configured or discovered.  |
 HostName  |
 Indicates the host name listed in the LSP, or the IS-IS system. The IS-IS system name uses global system name, if the host name is not configured.  |
 Type  |
 Indicates the SPBM I-SID type; either configured or discovered.  |
