Use the following procedure to delete accounts in enhanced secure mode.
  • You must enable enhanced secure mode in either the JITC or non-JITC sub-modes. As a best practice, use the non-JITC sub-mode because the JITC sub-mode is more restrictive and prevents the use of some troubleshooting utilities.
  • You must be an admin or privilege user to delete accounts.
    enable
    configure terminal
  2. Delete an account on the switch:
    password delete–user username WORD<1–255>
  3. Save the configuration:
    save config
    The save config command saves the configuration file with the filename configured as the primary configuration filename in boot config. Use the command show boot config choice to view the current primary and backup configuration filenames.
Delete an account for jsmith:
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#password delete-user user-name jsmith
Switch:1(config)#save config
Variable definitions
Use the data in the following table to use the password delete-user command.
Variable
Value
user-name WORD<1–255>
Specifies the user name.
