Configure ACE destination port entries to have the filter look for packets with a specific destination port.
The ACE exists.
The ACL exists.
 - Select Advanced Filters (ACE/ACLs).
 - Select the ACL tab.
 - Select the appropriate ACL.
 - Select ACE.
 - Select the appropriate ACE.
 - Select Proto.
 - Select the Destination Port tab.
 - Select Insert.
 - Specify the operator for the destination port.
 - Specify the port number or port list to match.
 - Select Insert.
Destination Port Field Descriptions
Use the data in the following table to use the Destination Port tab.
 Name  |
 Description  |
 AclId  |
 Specifies the ACL ID.  |
 AceId  |
 Specifies the ACE ID.  |
 Oper  |
 The eq and mask parameters specify an operator for a field match condition: equal to or mask. The mask operator is an implied eq on the mask bits.  |
 Port  |
 Specifies the port number. As noted at the bottom of the tab, potential entries include 0–65535, echo, ftpdata, ftpcontrol, ssh, telnet, dns, http, h.323, and undefined.  |
 OperMask  |
 Specifies the mask parameter, {0-0xFFFF}.  |
