View routes information to view the current configuration.
Not all parameters are available in non-default VRFs.
IPv6 host routes created for the IPv6 local interfaces do not display in the routing table.
Switch:1(config-if)#show ipv6 route
                                     IPv6 Routing Table Information - GlobalRouter
Destination Address/PrefixLen            NEXT HOP            NH VRF/ISID       VID/BID/TID  PROTO   COST  AGE   TYPE PREF
22:0:0:0:0:0:0:0/64                      42-VSP-8404             -               V-22        LOCAL   1     0     B    0
123:0:0:0:0:0:0:0/64                     39-4900-24XE            -               C-1         LOCAL   1     0     B    0
2 out of 2 Total Num of Route Entries displayed.
TYPE Legend:
A=Alternative Route, B=Best Route, E=Ecmp Route
Switch:1#show ipv6 route count-summary
                         IPv6 Route Summary - GlobalRouter
  VRF NAME      TOTAL     OSPF      RIP      BGP   STATIC    LOCAL     ISIS
  GlobalRouter   13       10       0        3        1        2        7
      Switch:1#show ipv6 route static
                              Static Route Information - GlobalRouter
DEST-IP                                  NET IFINDX(VID/BRT/TUN) ENABLE  STATUS           NAME
NEXT-HOP                                 PREFERENCE
22:0:0:0:0:0:0:0                         64  2059  (V-11     ) enable  NotReachable	ExtSer10
66:0:0:0:0:0:0:66                        5
1 out of 1 Total Num of Static Routes displayed.
Global IPv6 Static Routes Admin Status: enable
      Switch:1#show ipv6 route spbm-nh-as-mac
2001:cdab:0:0:0:0:0:0/32         42-VSP-8404           -           V-611        LOCAL   1   0     B    0
2002:cdab:0:0:0:0:0:0/32         VSP-8404              -           V-10         ISIS    1   0     B    0
Use the data in the following table to use the show ipv6 route command.
 Variable  |
 Value  |
 count-summary  |
 Shows the total number of OSPF, static, and local routes.  |
 dest WORD<0–46>  |
 Specifies the IPv6 destination network address. The prefix value must match the prefix length.  |
 next-hop WORD<0–46>  |
 Specifies the IPv6 address of the next hop on this route.  |
                             spbm-nh-as-mac  |
                             Shows the B-MAC address as the next hop rather than the host name.  |
 {slot/port[/sub-port]}  |
 Identifies a single slot and port. If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
 static  |
 Shows static IPv6 routes.  |
                             tunnel <1–2000>  |
                             Shows route entries for a specific tunnel ID.  |
 vlan<1-4059>  |
 Shows route entries for a specific VLAN ID.  |
 vrfWORD<1–16>  |
 Shows the VRF name.  |
 vrfidsWORD<1–256>  |
 Shows the VRF ID.  |
