Configure NLB Support
Use Microsoft Network Load Balancing (NLB) to share the workload among multiple clustering servers. For more information about software scaling capabilities, see VOSS Release Notes.
Ensure that the VLAN exists and has an associated IP address.
Use the following procedure to configure NLB support on an IP interface to enable or disable NLB support. The default value is NLB support disabled.
  • SPBM supports Network Load Balancing (NLB) Unicast and Multicast modes.
  • Static multicast ARP entries are not supported for NLB Unicast or NLB Multicast.
  • Multicast MAC flooding is not supported for NLB.
  • ARP entries for NLB server IP addresses do not age out when there is still client traffic coming to the NLB servers, even after the NLB servers are no longer reachable.
  1. In the navigation pane, expand Configuration > VLAN.
  2. Select VLANs .
  3. Select the Advanced tab.
  4. In the row for the VLAN, double-click the value in the NlbMode column.
  5. Select the appropriate value.
  6. Select Apply.
