Configure Ethernet MSTP MSTI
Use the following procedure to configure the Ethernet MSTP MSTI parameters on a port.
Configure Ethernet MSTP MSTI:
Switch(config-if)# spanning-tree mstp msti 62 priority 32
Use the data in the following table to use the spanning-tree mstp msti <1-63> command.
                             Variable  |
                             Value  |
                             <1–63>  |
                             Specifies the instance ID.  |
                             cost <1–200000000>  |
                             Configures the path cost for the port  |
                             force-port-state enable  |
                             Enables MSTI learning for the port.  |
                             {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
                             Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
                             priority <0–240>  |
                             Configures the priority for the port. Enter the priority value (0–240) as increments of 16.  |
