Use this task to disable a user account using EDM.
                Users with rwa access rights cannot be disabled. Only users with ro and rw access
                    rights can be disabled.
                In the navigation pane, expand
                Select General.
                Select the Multiple Users
                    tab.
 - View whether the user
account is enabled. To modify, double-click on the cell and select
false from the list.
                Select Apply.
