After you enable or disable certain modes and functions, you need to save the configuration, and then restart the switch for your change to take effect. This section lists parameters and indicates if they require a switch restart.
The following table lists parameters you configure in the CLI using the boot config flags command. For information on system flags and their configuration, see Boot Flag Configuration using CLI.
                             Flag  |
                             Restart  |
                             advanced-feature-bandwidth-reservation Note:
                        Exception: Only supported on VSP 7400 Series.  |
                             Yes  |
                             block-snmp  |
                             No  |
                             debug-config  |
                             Yes  |
                             debugmode  |
                             Yes  |
                             dvr-leaf-mode  |
                             No Note:
                        The switch does not require a restart when you enable the dvr-leaf-mode flag, as long as there is no unsupported configuration on the switch.  |
                             enhancedsecure-mode  |
                             Yes  |
                             factorydefaults [config-only | reset-all-files | zero-touch | zero-touch-config-only]  |
                             Yes  |
                             flow-control-mode  |
                             Yes  |
                             ftpd  |
                             No  |
                             hsecure  |
                             Yes  |
                             ipv6-egress-filter  |
                             Yes  |
                             ipv6-mode  |
                             Yes  |
                             logging  |
                             No  |
                             nni-mstp  |
                             Yes  |
                             reboot  |
                             No  |
                             spanning-tree-mode  |
                             Yes  |
                             spbm-config-mode  |
                             Yes  |
                             sshd  |
                             No  |
                             telnetd  |
                             No  |
                             tftpd  |
                             No  |
                             trace-logging  |
                             No  |
                             urpf-mode  |
                             Yes  |
                             verify-config  |
                             Yes  |
                             vrf-scaling  |
                             Yes  |
                             vxlan-gw-full-interworking-mode Note:
                             Yes  |
