Use the following procedure to create and configure an IKE Phase 1 policy.
Policy Field Descriptions
Use the data in the following table to use the Policy tab.
                                 Name  |
                                 Description  |
                                 LocalIfIndex  |
                                 Specifies the Interface Index of the local address. Only port and vlan interfaces are supported.  |
                                 LocalAddrType  |
                                 Specifies whether the local address is an IPv4 or IPv6 address.  |
                                 LocalAddr  |
                                 Specifies the address of the local peer.  |
                                 RemoteAddrType  |
                                 Specifies whether the remote address is an IPv4 or IPv6 address.  |
                                 RemoteAddr  |
                                 Specifies the address of the remote peer.  |
                                 Name  |
                                 Specifies the name given to the policy. The name should be assigned while creating the policy. You cannot change the name after the policy is created.  |
                                 ProfileName  |
                                 Specifies the name of the profile that should be used for this policy.  |
                                 ProfileVersion  |
                                 Specifies the profile version used for the policy.  |
                                 PeerName  |
                                 Specifies the peer name.  |
                                 AuthenticationMethod  |
                                 Specifies the proposed authentication method for the Phase 1 security association. The default authentication method is pre-shared key.  |
                                 PSKValue  |
                                 Specifies the value of the Pre-Shared Key if the authentication method is set to PSK.  |
                                 DPDTimeout  |
                                 Specifies the Dead Peer Detection timeout in seconds. Default value is 300 seconds.  |
                                 P2PFS  |
                                 Specifies whether or not the perfect forward secrecy (PFS) is used when refreshing keys. To use PFS, select enable. The default value is disable.  |
                                 P2PfsUseIkeGroup  |
                                 Specifies whether or not to use the same GroupId (Diffie-Hellman Group) for phase 2 as was used in phase 1. Ignore this entry if P2PFS is disabled. The default value is enable.  |
                                 P2PfsDHGroup  |
                                 Specifies the Diffie-Hellman group to use for phase 2 when P2PFS is enabled and P2PfsUseIkeGroup is disabled. The default value is mod1024.  |
                                 AdminState  |
                                 Specifies whether the policy is administratively enabled or disabled. The default value is disable.  |
                                 OperStatus  |
                                 Shows is the policy is operationally up or down.  |
                                 RevocationCheckMethod  |
                                 Specifies the revocation check method as OCSP, CRL or none.  |
