Configure VRRPv3 Checksum
Perform this procedure to configure VRRPv3 checksum on either a brouter port or a VLAN.
 - Select VRRP.
 - Select the V3 Checksum tab.
 - Select Insert.
 - In Interface, select Port or Vlan.
 - Select the ports or VLANs from the list, and then select OK.
 - Select a type of checksum computation.
 - Select a VRRP version.
 - Select Insert.
V3 Checksum Field Descriptions
Use the data in the following table to use the V3 Checksum tab.
 Name  |
 Description  |
 Interface  |
 Shows VRRPv3 information about a specified interface.  |
 rcIpConfIfIndex  |
 Shows the index value that uniquely identifies the interface to which this entry applies.  |
 ChkSumComputation  |
 Specifies the type of checksum computation, with Pseudo Header or without Pseudo Header.  |
 VrrpVersion  |
 Specifies the VRRP version as unspecified, v2, or v3.  |
