Perform this procedure to configure basic parameters on Extreme Integrated Application Hosting (IAH) ports, for example, auto negotiation, QoS level, and remote monitoring.
  1. In the navigation pane, expand Configuration > Edit > Insight Port.
  2. Select the IAH port you want to configure.
  3. Select the Interface tab.
  4. In Name, type a name for the IAH port.
  5. Configure the parameters as required.
  6. Select Apply.
Interface Field Descriptions
Use data in the following table to use the Interface tab.
Name
Description
Index
Specifies the index of the Extreme Integrated Application Hosting (IAH) port, written in the slot/port[/sub-port] format.
Name
Specifies the name of the IAH port.
Descr
Specifies the information about the interface.
Type
Specifies the type of connector plugged in the IAH port.
Mtu
Specifies the Maximum Transmission Unit (MTU) for the port. The size of the largest datagram which can be sent or received on the interface, specified in octets. For interfaces that are used for transmitting network datagrams, this is the size of the largest network datagram that can be sent on the interface.
PhysAddress
Specifies the physical address of the IAH port. The address of the interface at the protocol layer immediately below the network layer in the protocol stack. For interfaces which do not have such an address (like a serial line), this object should contain an octet string of zero length.
VendorDescr
Specifies the vendor of the connector plugged in the IAH port.
DisplayFormat
Specifies the slot and port numbers (slot/port).
AdminStatus
Specifies the operational status of the IAH port. The testing state indicates that no operational packets can be passed.
OperStatus
Specifies the current status of the IAH port. The testing state indicates that no operational packets can be passed.
LicenseControlStatus
Specifies the IAH port license status.
ShutdownReason
Specifies the reason for the IAH port state change.
LastChange
Specifies the timestamp of the last change.
LinkTrap
Enables or disables link trapping. The default is enabled.
AutoNegotiate
Enables or disables auto-negotiation for the IAH port. The default is true (enabled).
AutoNegAd
Specifies the port speed and duplex abilities to be advertised during link negotiation.
The abilities specified in this object are only used when auto-negotiation is enabled on the IAH port. If all bits in this object are disabled, and auto-negotiation is enabled on the IAH port, then the physical link process on the IAH port will be disabled (if hardware supports this ability).
Any change in the value of this bit map will force the switch to restart the auto-negotiation process.
The capabilities being advertised are either all the capabilities supported by the hardware or the user-configured capabilities, which is a subset of all the capability supported by hardware.
By default, all capabilities supported by the hardware are enabled.
AdminDuplex
Specifies the administrative duplex setting for the IAH port.
OperDuplex
Specifies the operational duplex setting for the IAH port.
AdminSpeed
Specifies the administrative speed for the IAH port.
OperSpeed
Specifies the operational speed for the IAH port.
QoSLevel
Specifies the Quality of Service (QoS) level for the IAH port. The default is level1.
DiffServ
Enables the Differentiated Service feature for the IAH port. The default is enabled.
Layer3Trust
Specifies if the system should trust Layer 3 packets coming from access links or core links only. The default is core.
Layer2Override8021p
Specifies whether Layer 2 802.1p override is enabled or disabled. The default is disabled.
MltId
Specifies the MLT ID associated with the IAH port. The default is 0.
Locked
Specifies if the IAH port is locked. The default is false.
UnknownMacDiscard
Enables the functionality to discard packets with an unknown source MAC address, and prevents the other IAH port from sending packets with the same MAC address as the destination MAC address. The default is disabled.
DirectBroadcastEnable
Specifies if the IAH port forwards direct broadcast traffic.
A directed broadcast is a frame sent to the subnet broadcast address on a remote IP subnet. By disabling or suppressing directed broadcast on an interface, all frames sent to the subnet broadcast address for a local router interface are dropped. Disabling this function protects a host from possible denial of service (DoS) attacks.
With the feature enabled, the Control Processor (CP) does not receive a copy of the directed broadcast. As a result, the system does not respond to a subnet broadcast ping sent from a remote subnet.
OperRouting
Specifies the routing status of the IAH port. The default is disabled.
HighSecureEnable
Enables or disables the high secure feature for the IAH port. The default is disabled.
RmonEnable
Enables or disables Remote Monitoring (RMON) on the IAH port. The default is disabled.
FlexUniEnable
Enables or disables Flex UNI on the IAH port. The default is disabled.
EgressRateLimitState
Enables or disables egress port-based shaping to bind the maximum rate at which traffic leaves the IAH port. The default is disabled.
EgressRateLimit
Specifies the egress rate limit in Kbps. Different hardware platforms provide different port speeds.
The default is 0.
TxFlowControl
Specifies if the IAH port is sending pause frames. The default is disabled.
Note:
You must enable the flow control feature globally.
TxFlowControlOperState
Specifies the operational state of flow control.
BpduGuardTimerCount
Specifies the duration since when the IAH port is disabled. When the BpduGuardTimerCount reaches the BpduGuardTimeout value, the IAH port is enabled.
BpduGuardTimeout
Specifies the time (in seconds) for the IAH port-state recovery. After the IAH port is disabled by the BPDU guard, the IAH port remains in the disabled state until this timer expires.
The default is 120 seconds. If you configure the value to 0, the expiry is infinity.
BpduGuardAdminEnabled
Enables or disables BPDU Guard on the IAH port. The default is disabled.
ForwardErrorCorrection
Configures one of the following options for Forward Error Correction (FEC) on the IAH port:
  • CL 91
  • CL 108
  • CL 74
  • disable
  • auto
The disable option disables this configuration on the port.
ForwardErrorCorrectionApplicability
Displays whether FEC is applicable on the interface.
OperAutoNegotiate
Shows the operational state of Auto-Negotiation.
OperForwardErrorCorrection
Shows the negotiated operational FEC clause.
If the value is off, the port supports FEC and is up but not configured for FEC. If the value is notApplicable, the port does not support FEC. If the value is unknown, the port supports FEC but is down.
Action
Specifies the following actions on the IAH port:
  • none - no action.
  • flushMacFdb - flush the MAC forwarding table.
  • flushArp - flush the ARP table.
  • flushIp - flush the IP route table.
  • flushAll - flush all tables.
  • triggerRipUpdate - manually triggers a RIP update.
  • clearLoopDetectAlarm - clears the loop detection alarm on the IAH port.
The default is none.
Result
Specifies the result of the selected action. The default is none.
AutoSense
Enables or disables Auto-sense on the specific port. The default value is disabled for existing configurations but enabled for new Zero Touch Fabric Configuration deployments.
AutoSenseKeepAutoConfig
Retains the Auto-sense configuration if you disable Auto-sense on the port. The dynamic configuration becomes a manual configuration and is visible in the show running-config output.
AutoSenseState
Displays the Auto-sense port state.
CustomAutoNegAdOrigin
Specifies the origin of Custom Auto Negotiation Advertisements (CANA) configuration on the port. The supported values are:
  • config - Set by the user.
  • radius - Set by the Remote Authentication Dail-In User Service (RADIUS) attribute.
BpduGuardOrigin
Specifies the origin of BPDU Guard configuration on the port. The supported values are:
