View the protocol directory to see the list of protocols that RMON2 can monitor. You cannot change the list of protocols.
The protocol directory MIB is enabled by default for the predefined protocols.
 - Select Protocol Directory.
 - Select the Protocol Directories tab.
Protocol Directories Field Descriptions
The following table defines parameters for the Protocol Directories tab.
 Name  |
 Description  |
 Index  |
 Shows a unique identifier for the entry in the table.  |
 Protocol  |
 Shows the protocols RMON2 can monitor:
 Note:
RMON2 can count application packets received on a platform, even if the application is not enabled or supported, before dropping them.  |
 AddressMapConfig  |
 Describes and configures the probe support for the network layer and application layer host tables for this protocol. The value can be one of the following:
 If the value is supportedOn, the probe adds entries to the Address Map tab that maps the network layer address to the MAC layer address.  |
 HostConfig  |
 If the value is supportedOn, the probe adds entries to the Host Control tab to collect statistics for network layer and application layer hosts.  |
 MatrixConfig  |
 Owner  |
 Shows the entity that configured this entry.  |
