- In the navigation pane, expand Configuration > IPv6.
 - Select IPv6 RIPng.
 - Select the Stats tab.
Stats Field Descriptions
Use the data in the following table to use the Stats tab.
 Name  |
 Description  |
 IfIndex  |
 Shows the unique value to identify an IPv6 interface.  |
 RcvBadPackets  |
 The number of RIPng response packets received by the RIP process that were subsequently discarded for any reason (examples: a version 0 packet or an unknown command type).  |
 RcvBadRoutes  |
 The number of routes, in valid RIPng packets, that were ignored for any reason (examples: unknown address family or invalid metric).  |
 SentUpdates  |
 The number of triggered RIPng updates actually sent on this interface.  |
 RcvUpdates  |
 The number of triggered RIPng updates actually received on this interface. This explicitly does not include full updates received containing new information.  |
