View the DvR interfaces on either a Controller or a Leaf node.
On Controllers, DvR interfaces are created when you configure IP on a DvR enabled Layer 2 VSN (VLAN, I-SID). Only Controllers display the administrative state of the interfaces because this is where you enable or disable the interfaces. The Leaf nodes display DvR interface information that is pushed from the Controllers, for example, subnet routes or gateway IP addresses for the Layer 2 VSNs.
Ensure that you enable DvR globally on the node.
View DvR interfaces on a Controller node:
You can view DvR interface information on all interfaces or for a specific Layer 3 I-SID, VRF, or VRF ID.
Switch:1#show dvr interfaces
                                                     DVR Interfaces
        Admin    SPBMC  IGMP
Interface       Mask           L3ISID  VRFID    L2ISID     VLAN     GW IPv4    State    State  Version
50.0.1.2        255.255.0.0    55500   1        50500      500      50.0.1.1   enable   disable 2
1 out of 1 Total Num of DVR Interfaces displayed
View DvR interfaces on a Leaf node:
You can view DvR interface information on all interfaces or for a specific Layer 3 I-SID. Viewing the interface information for a specific VRF or VRF ID is not supported on a DvR Leaf node.
Switch:1#show dvr interfaces l3isid 401
                               DVR Interfaces
40.1.0.0        255.255.0.0    401        2        10401      77       40.1.1.11
40.2.0.0        255.255.0.0    401        2        10402      78       40.2.1.11
40.3.0.0        255.255.0.0    401        2        10403      79       40.3.1.11
40.4.0.0        255.255.0.0    401        2        10404      80       40.4.1.11
4 out of 4 Total Num of DVR Interfaces displayed
Variable definitions
Use the data in the following table to use the show dvr interfaces command.
 Variable  |
 Value  |
 l3isid  |
 Specifies the Layer 3 I-SID of the DvR interface. The range is 0 to 16777215.  |
 vrf  |
 Specifies the VRF name.  |
 vrfids  |
 Specifies the VRF ID. The range is 0 to 512.  |
