Modify the egress mappings to change the mappings between the QoS levels and the IEEE 802.1p bits.
Do not change the default values. If you change the values, make sure that the values are consistent on all other devices in the network. Inconsistent mapping of table values can result in unpredictable service levels.
 - Select Mapping Tables.
 - Select the Egress QoS to 8021p tab.
 - Double-click Outleee8021P to change the value.
 - Select Apply.
Egress QoS to 8021p Field Descriptions
Use the data in the following table to use the Egress QoS to 8021p tab.
 Name  |
 Description  |
                                 QosLevel  |
                                 Specifies the QoS level of the outgoing packet.  |
                                 Outleee8021P  |
                                 Specifies the equivalent value of the IEEE 802.1p bit.  |
