The following table defines parameters for the radius server host command.
| Variable | Value |
| WORD<0-255> |
                             Configures a host server. WORD <0–255> specifies the IPv4 address, IPv6 address, or fully qualified domain name (FQDN). If you use an FQDN, you must also configure the switch to use DNS.  |
| used-by |
                             Specifies how the server functions. Configures the server for one of the following:
| secure-enable |
                             Enables RADSec on the RADIUS server.  |
