range
Specifies a range of addresses for routes matching address/mask for OSPF summarization
Syntax
range <IP/M>
Parameters
range <IP/M>
<IP/M> Specifies the routes matching address/mask for summarization.
Note: This command is applicable for a ABR (Area Border Router) only.
nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#range 172.16.10.0/24
nx9500-6C8809(config-profile default-nx5500-router-ospf-area-0.0.0.1)#show context
  area 0.0.0.1
   authentication simple-password
   area-type stub default-cost 1
Related Commands
no (area-config-mode-command) Removes the configured network IP range
