city
Configures a wireless client filter based on the city name
Syntax
city [any|contains|exact|not-contains]
city [any|exact <WORD>|contains <WORD>|not-contains <WORD>]
Parameters
city
Specifies a wireless client filter based on how the ‘city‘ name, returned by the RADIUS server, matches the provided expression. Select one of the following options: any, contains, exact, or not-contain.
any
No specific city associated with this user-defined role. This role can be applied to any wireless client from any city.
contains <WORD>
The role is applied only when the city name, returned by the RADIUS server, contains the string specified in the role.
  • <WORD> – Specify the string to match (this is case sensitive, and is compared against the city name returned by the RADIUS server). It should contain the provided expression.
exact <WORD>
The role is applied only when the city name, returned by the RADIUS server, exactly matches the string specified in the role.
  • <WORD> – Specify the exact string to match (this is case sensitive, and is compared against the city name returned by the RADIUS server). It should be an exact match.
not-contains <WORD>
The role is applied only when the city name, returned by the RADIUS server, does not contain the string specified in the role.
  • <WORD> – Specify the string not to match (this is case sensitive, and is compared against the city name returned by the RADIUS server). It should not contain the provided expression.
nx9500-6C8809(config-role-policy-test-user-role-testing)#city exact SanJose
nx9500-6C8809(config-role-policy-test-user-role-testing)#show context
 user-role testing precedence 10
  authentication-type eq kerberos
  ap-location contains office
  captive-portal authentication-state pre-login
  city exact SanJose
Related Commands
no
Removes the city name configured with this user-defined role
