Release 7.9.1.0
Revision AB
The following updates have been made in Revision AB of this guide.
Updates Description
gre The devices that support GRE Tunneling and the Maximum GRE Tunnels Supported have been corrected.
Revision AA
The following updates have been made in Revision AA of this guide.
Update Description
Hardware descriptions and specifications contained in this chapter have been relocated to the Appendices in this Guide.
Log in to the WiNG Controller New procedure
Discovery of available bonjour services can be restricted to service VLANs
customize Added 6 GHz radio and bridge options in show-wireless-radio rf-mode command
radio-resource-measurement
  • Corrected the default setting for the radio-resource-management parameter: the correct default setting is enabled.
  • Updated to add tpc-report parameter, which enables sending the tpc-report element in beacons and probe responses.
Method used to enable and access the Flash user interface on a device has changed
nova (management-policy) Updated and corrected NOVA UI access instructions
gre Added support for up to 1000 tunnels
data-rates Added 6 GHz option for the data-rates command in the interface-config-radio-instance.
rts-threshold Beginning in WiNG 7.9.1, for optimal performance, the recommended rts-threshold value to use is 2347.
ip Updated default-gateway static-route and dhcp-client priority setting value range from <1 - 1800> to <1 - 8000>
data-rates (meshpoint-config) Corrections and updates made
