match
      Sets the match clauses. Each route map
         entry has a set of match clauses used to segregate and filter packets. Packets can be
         segregated using any one of the following criteria:The action taken for filtered packets is determined by the mark (action) clauses.
            If no action is defined, the default is to fallback to destination-based routing for
            packets satisfying the match criteria. For more information on configuring mark clauses,
            see mark. And for more information on fallback action, see fallback.
            - Access Points:
               AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
               AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
         match [incoming-interface|ip|ip-access-list|wireless-client-role|wlan]
         match incoming-interface [<ROUTER-IF-NAME>|pppoe1|serial <SLOT-ID> <PORT-ID>
<CHANNEL-GROUP-ID>|vlan <1-4094>|wwan1]
         match ip dscp <0-63>
         match ip-access-list <IP-ACCESS-LIST-NAME>
         match wireless-client-role <ROLE-POLICY-NAME> <ROLE-NAME>
         match wlan <WLAN-NAME>
      Parameters
                     | incoming-interface | Sets the incoming SVI match clause. Specify an interface name. |
                     | <ROUTER-IF-NAME> | Specifies the layer 3 interface name (route interface) |
                     | pppoe1 | Specifies the PPP over Ethernet interface |
                        <CHANNEL-GROUP-ID> | Specifies the serial interface‘s slot, port, and
                        channel group IDs. |
                     | vlan <1-4094> | Specifies the VLAN interface ID
                           <1-4094> – Specify a VLAN ID from 1 - 4094. |
                     | wwan1 | Specifies the WAN interface name |
                     | ip dscp <0-63> | Sets the DSCP match clause
                           <0-63> – Specify
                              a value from 0 - 63. The defined DSCP value is used as a matching
                              clause for this route map. |
                     | ip-access-list <IP-ACCESS-LIST-NAME> | Sets the match clause using a pre-configured IP access list
                           <IP-ACCESS-LIST-NAME> – Specify a pre-configured IP access list
                              name. |
                     | wireless-client-role <ROLE-POLICY-NAME> <ROLE-NAME> | Sets the wireless client role match clause
                           <ROLE-POLICY-NAME> – Specify a pre-configured role policy.
                                 <ROLE-NAME> – Specify a pre-configured role within
                                    it. |
                     | wlan <WLAN-NAME> | Sets the incoming WLAN match clause
                           <WLAN-NAME> –
                              Specify a WLAN name. |
         nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#match incoming-interface pppoe1
         nx9500-6C8809(config-routing-policy-testpolicy-route-map-1)#show context
 route-map 1
  default-next-hop wwan1
  mark ip dscp 7
