profile
Configures profile related commands.
If no parameters are given, all profiles are selected.
- Access Points: AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP6522, AP6562, AP7161, AP7502,
AP8533.
- Service Platforms:
Syntax
profile {anyap|ap505|ap510|containing|filter|nx5500|nx75xx|nx9000|nx9600|vx9000}
profile {anyap|ap505|ap510|nx5500|nx75xx|nx9000|nx9600|vx9000} <DEVICE-PROFILE-NAME>
profile {containing <DEVICE-PROFILE-NAME>} {filter type [ap505|ap510||nx75xx|nx9000|nx9600|
vx9000]}
profile {filter type [ap505|ap510|nx5500|nx75xx|nx9000|nx9600|vx9000]}
Parameters
profile {anyap|ap505|ap510|rfs6000|nx5500|nx75xx|nx9000|nx9600|vx9000}
profile <DEVICE-TYPE> <DEVICE-PROFILE-NAME> |
Configures device profile commands. If no device profile is specified,
the system configures all device profiles. Select ‘anyap‘ to configure a profile applicable to any access
point.
profile {containing <DEVICE-PROFILE-NAME>} {filter type [ap505|ap510|nx5500|nx75xx|
profile |
Configures device profile commands |
containing <DEVICE-PROFILE-NAME> |
Optional. Configures profiles that contain a specified sub-string in the
hostname
- <DEVICE-PROFILE-NAME> – Specify a substring in the profile name
to filter profiles.
filter type |
Optional. An additional filter used to configure a specific type of
device profile. If no device type is specified, the system configures all
device profiles.
- type – Filters profiles by the device type.
Select a device type from the following options:
The options are: AP505, AP510, NX5500, NX7500,
NX9500, NX9600, and VX9000.
profile {filter type[ap505|ap510|nx5500|nx75xx|nx9000|nx9600|vx9000]}
profile |
filter type |
device profiles.
<DEVICE>(config)#profile nx9000 test-NX9500
<DEVICE>(config-profile-test-NX9500)#?
Profile Mode commands:
adopter-auto-provisioning-policy-lookup Use centralized auto-provisioning
policy when adopted by another
controller
adoption Adoption configuration
adoption-mode Configure the adoption mode for the
access-points in this RF-Domain
alias Alias
application-policy Application Poicy configuration
area Set name of area where the system
is located
arp Address Resolution Protocol (ARP)
auto-learn Auto learning
autogen-uniqueid Autogenerate a unique id
autoinstall Autoinstall settings
bridge Ethernet bridge
captive-portal Captive portal
cdp Cisco Discovery Protocol
cluster Cluster configuration
configuration-persistence Enable persistence of configuration
across reloads (startup config
file)
controller WLAN controller configuration
critical-resource Critical Resource
crypto Encryption related commands
database Database command
device-onboard Device-onboarding configuration
device-upgrade Device firmware upgrade
diag Diagnosis of packets
dot1x 802.1X
dpi Enable Deep-Packet-Inspection
(Application Assurance)
dscp-mapping Configure IP DSCP to 802.1p
priority mapping for untagged
frames
eguest-server Enable ExtremeGuest Server
functionality
email-notification Email notification configuration
enforce-version Check the firmware versions of
devices before interoperating
environmental-sensor Environmental Sensors Configuration
events System event messages
export Export a file
file-sync File sync between controller and
adoptees
floor Set the floor within a area where
the system is located
gre GRE protocol
http-analyze Specify HTTP-Analysis configuration
interface Select an interface to configure
ip Internet Protocol (IP)
ipv6 Internet Protocol version 6 (IPv6)
l2tpv3 L2tpv3 protocol
l3e-lite-table L3e lite Table
led Turn LEDs on/off on the device
led-timeout Configure the time for the led to
turn off after the last radio state
change
legacy-auto-downgrade Enable device firmware to auto
downgrade when other legacy devices
are detected
legacy-auto-update Auto upgrade of legacy devices
lldp Link Layer Discovery Protocol
load-balancing Configure load balancing parameter
logging Modify message logging facilities
mac-address-table MAC Address Table
mac-auth 802.1X
management-server Configure management server address
memory-profile Memory profile to be used on the
device
meshpoint-device Configure meshpoint device
parameters
meshpoint-monitor-interval Configure meshpoint monitoring
interval
min-misconfiguration-recovery-time Time interval to check controller
connectivity after configuration is
received
mint MiNT protocol
misconfiguration-recovery-time Check controller connectivity after
configuration is received
neighbor-inactivity-timeout Configure neighbor inactivity
timeout
neighbor-info-interval Configure neighbor information
exchange interval
no Negate a command or set its
defaults
noc Configure the noc related setting
nsight NSight
ntp Ntp server WORD
offline-duration Set duration for which a device
remains unadopted before it
generates offline event
otls Omnitrail Location Server
power-config Configure power mode
preferred-controller-group Controller group this system will
prefer for adoption
preferred-tunnel-controller Tunnel Controller Name this system
will prefer for tunneling extended
vlan traffic
radius Configure device-level radius
authentication parameters
raid RAID
remote-debug Configure remote debug parameters
remove-override Remove configuration item override
from the device (so profile value
takes effect)
rf-domain-manager RF Domain Manager
router Dynamic routing
slot PCI expansion Slot
spanning-tree Spanning tree
traffic-class-mapping Configure IPv6 traffic class to
802.1p priority mapping for
untagged frames
traffic-shape Traffic shaping
trustpoint Assign a trustpoint to a service
tunnel-controller Tunnel Controller group this
controller belongs to
use Set setting to use
vrrp VRRP configuration
vrrp-state-check Publish interface via OSPF/BGP only
if the interface VRRP state is not
BACKUP
wep-shared-key-auth Enable support for 802.11 WEP
shared key authentication
zone Configure Zone name
clrscr Clears the display screen
commit Commit all changes made in this
session
do Run commands from Exec mode
end End current mode and change to EXEC
mode
exit End current mode and down to
previous mode
help Description of the interactive help
system
revert Revert changes
service Service Commands
show Show running system information
write Write running configuration to
memory or terminal
Related Commands
no
Removes a profile and its associated configurations |
