client-identity-mode-commands
The following table summarizes the client-identity configuration mode commands:
Table 1. Client-Identity-Mode Commands
Command Description
dhcp Configures the DHCP option match criteria for device fingerprinting
dhcp-match-message-type Configures the DHCP message type for device fingerprinting
no (client-identity-config-mode) Removes the DHCP option (used for client identification) configurations
