power
interface-config-radio-instance
Configures the selected radio‘s transmit power. Use this command to manually set the transmit power of the selected radio, or select the smart mode by which the transmit power is determined.
Syntax
power [<1-30>|smart]
Parameters
power Configures the selected radio‘s transmit power
<1-30> Configures the transmit power from 1 - 30 dBm (actual power could be lower based on regulatory restrictions)
For APs with dual or three radios, use this option to manually configure each radio with a unique transmit power in respect to its intended client support function.
smart Enables Smart RF to determine the optimum transmit power needed. Use this option to let Smart RF determine the selected radio's transmit power. If you are using this option for RF management, ensure that a Smart RF policy is configured and applied to the AP's RF Domain context. You can also use the default Smart RF policy.
Note: By default, APs use Smart RF to determine transmit power.
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#power 12
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
 interface radio1
  power 12
  data-rates b-only
  placement outdoor
  mesh client
  off-channel-scan channel-list 2.4GHz 1
  guard-interval long
  aggregation ampdu tx-only
  aeroscout forward
  ekahau forward ip 172.16.10.1 port 3
  non-unicast tx-rate bss 1 dynamic-all
  non-unicast tx-rate bss 2 highest-basic
  non-unicast tx-rate bss 3 highest-basic
  non-unicast tx-rate bss 4 highest-basic
  non-unicast tx-rate bss 5 highest-basic
  non-unicast tx-rate bss 6 highest-basic
  non-unicast tx-rate bss 7 highest-basic
--More--
Related Commands
no (radio-interface-config-command) Resets a radio‘s transmit power
