no
interface-config-ge-instance
Removes or reverts the selected Ethernet port settings
Syntax
no [captive-portal-enforcement|cdp|channel-group|description|dot1x|duplex|eee|
ip|ipv6|lacp|lacp-channel-group|lldp|mac-auth|power|qos|shutdown|spanning-tree|speed|switchport|use]
no [captive-portal-enforcement|channel-group|description|duplex|mac-auth|shutdown|speed]
no [cdp|lldp] [receive|transmit]
no dot1x [authenticator [guest-vlan|host-mode|max-reauth-req|port-control|reauthentication|timeout [quiet-period|reauth-period]]|supplicant]
no eee
no ip [arp [header-mismatch-validation|trust]|dhcp trust]
no ipv6 [dhcpv6 trust|nd [header-mismatch-validation|raguard|trust]]
no [lacp port-priority|lacp-channel-group]
no power {best-effort|limit|priority}
no qos trust [802.1p|cos|dscp]
no spanning-tree [bpdufilter|bpduguard|force-version|guard|link-type|mst|portfast]
no switchport [access vlan|mode|trunk native tagged]
no use [ip-access-list|ipv6-access-list|mac-access-list] in
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes or reverts this Ethernet port settings based on the parameters passed
Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
nx9500-6C8809(config-profile-default-nx5500-if-ge1)#no cdp
nx9500-6C8809(config-profile-default-nx5500-if-ge1)#no duplex
ap505-13403B(config-device-94-9B-2C-13-40-38-if-ge2)#show context
 interface ge2
  eee
ap505-13403B(config-device-94-9B-2C-13-40-38-if-ge2)#n
ap505-13403B(config-device-94-9B-2C-13-40-38-if-ge2)#no eee
 interface ge2
  no eee
