max-clients
interface-config-radio-instance
Configures the maximum number of wireless clients allowed to associate with this radio
Syntax
max-clients <0-256>
Parameters
max-clients <0-256>
max-clients <0-256> Configures the maximum number of clients allowed to associate with a radio, subject to the access point‘s limit. Specify a value from 0 - 256. The default is 256.
Note: The maximum number of clients supported per radio is 256. On the AP, the maximum number of clients supported is 500. If both radios are up, the total number of wireless clients that can associate with the AP is 500.
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#max-clients 100
nx9500-6C8809(config-profile-510TestProfile-if-radio1)#show context
 interface radio1
  description "Primary radio to use"
  channel 1
  data-rates b-only
  beacon period 50
  beacon dtim-period bss 1 5
  beacon dtim-period bss 2 2
  beacon dtim-period bss 12 5
  beacon dtim-period bss 13 5
  beacon dtim-period bss 14 5
  beacon dtim-period bss 15 5
  beacon dtim-period bss 16 5
  antenna-gain 12.0
  guard-interval long
  aggregation ampdu tx-only
  aeroscout forward
  ekahau forward ip 172.16.10.1 port 3
  antenna-mode 2x2
  antenna-diversity
  max-clients 100
  airtime-fairness prefer-ht weight 6
  lock-rf-mode
  extended-range 15
  antenna-downtilt
Related Commands
no (radio-interface-config-command) Resets the maximum number of wireless clients allowed to associate with a radio
