no (nsight-policy-config-commands)
Removes NSight policy settings or reverts them to default values
Syntax
no [enable|mandatory app stats app-group <APPLICATION-GROUP-NAME>|server host [<IPv4>|<HOST-NAME>|<IPv6>]]]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes NSight policy settings based on the parameters passed
The following example shows the NSight policy ‘test2‘ settings before the ‘no‘ command is executed:
nx9510-6C8A5C(config-nsight-policy-test2)#show context
nsight-policy test2
 server host 172.22.0.153 http
nx9510-6C8A5C(config-nsight-policy-test2)#no server host 172.22.0.153
The following example shows the NSight policy ‘test2‘ settings after the ‘no‘ command is executed:
nsight-policy test2
