local-ip-address
Configures the tunnel's source IP address. If no IP address is specified, the tunnel's source IP address is automatically configured based on the tunnel peer's IP address.
Syntax
local-ip-address <IP>
Parameters
Configures the L2TPv3 tunnel‘s source IP address
  • <IP> – Specify the tunnel‘s IP address. Ensure the IP address is available (or will become available - virtual IP) on an interface. Modifying a tunnel‘s local IP address re-establishes the tunnel.
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#local-ip-address 172.16.10.2
nx9500-6C8809(config-profile default-nx5500-l2tpv3-tunnel-Tunnel1)#show context
 l2tpv3 tunnel Tunnel1
  hostname TunnelHost1
Related Commands
no
Resets the tunnel‘s local IP address and re-establishes the tunnel
