apply-to-local-packets
Enables PBR for locally generated packets (packets generated by the device). When enabled, this option implements the match and action clauses defined within route maps. This option is enabled by default.
Syntax
Parameters
None
nx9500-6C8809(config-routing-policy-testpolicy)#apply-to-local-packets
Related Commands
no (routing-policy-config-mode-command) Disables PBR for locally generated packets
