no
nat-pool-config-instance
Removes address(es) configured with this NAT pool
Syntax
no address [<IP>|range <START-IP> <END-IP>]
Parameters
no address [<IP>| range <START-IP> <END-IP>] Removes a single IP address or a range of IP addresses from this NAT pool
Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
nx9500-6C8809(config-profile-testNX5500-nat-pool-pool1)#show context
 ip nat pool pool1
  address range 172.16.10.2 172.16.10.8
nx9500-6C8809(config-profile-testNX5500-nat-pool-pool1)#no address range 1
 ip nat pool pool1
