no (smart-rf-policy-config-mode-command)
Negates a command or sets its default. When used in the config Smart RF policy mode, the no command disables or resets Smart RF settings.
Syntax
no [area|assignable-power|avoidance-time|channel-list|channel-width|coverage-hole-recovery|
enable|group-by|interference-recovery|neighbor-recovery|select-shutdown|smart-ocs-monitoring]
no area <AREA-NAME> channel-list [2.4GHZ|5GHZ]
no assignable-power [2.4GHZ|5GHZ|6GHZ] [max|min]
no [channel-list|channel-width] [2.4GHZ|5GHZ|6GHZ]
no coverage-hole-recovery [client-threshold|coverage-interval|interval|snr-threshold]
[2.4GHZ|5GHZ]
no avoidance-time [adaptivity|dfs]
no enable
no group-by [area|floor]
no interference-recovery {channel-hold-time|channel-switch-delta [2.4GHZ|5GHZ|6GHZ]|
client-threshold|interference|neighbor-offset|noise|noise-factor}
no neighbor-recovery {dynamic-sampling {retries|threshold}|power-hold-time|power-threshold
[2.4GHZ|5GHZ]}
no select-shutdown {cci-high-threshold|cci-low-threshold|frequency|frequency-limiter}
no smart-rf-monitoring {awareness-override [schedule <1-3>|threshold]|client-aware [2.4GHZ|5GHZ|6GHZ]|
extended-scan-frequency [2.4GHZ|5GHZ]|frequency [2.4GHZ|5GHZ]|off-channel-duration [2.4GHZ|5GHZ|6GHZ]|
power-save-aware [2.4GHZ|5GHZ]|sample-count [2.4GHZ|5GHZ]|voice-aware [2.4GHZ|5GHZ|6GHZ]}
Parameters
no <PARAMETERS>
no <PARAMETERS> Negates a command or sets its default. When used in the config Smart RF policy mode, the no command disables or resets the Smart RF policy settings.
The following example shows the Smart RF policy ‘test‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-smart-rf-policy-test)#show context
smart-rf-policy test
 group-by floor
 sensitivity custom
 assignable-power 2.4GHz max 20
 assignable-power 2.4GHz min 8
 channel-list 2.4GHz 1,12
 channel-width 5GHz auto
 channel-width 2.4GHz auto
 area test channel-list 2.4GHz 1,2,3
 avoidance-time dfs 300
 no smart-ocs-monitoring
 smart-ocs-monitoring frequency 5GHz 3
 smart-ocs-monitoring frequency 2.4GHz 3
 smart-ocs-monitoring sample-count 5GHz 3
 smart-ocs-monitoring extended-scan-frequency 5GHz 0
 smart-ocs-monitoring extended-scan-frequency 2.4GHz 9
 smart-ocs-monitoring awareness-override schedule 1 12:30 20:30 all
 interference-recovery client-threshold 255
 interference-recovery channel-switch-delta 5GHz 5
 interference-recovery channel-switch-delta 2.4GHz 5
 neighbor-recovery power-threshold 5GHz -65
 neighbor-recovery power-threshold 2.4GHz -65
 select-shutdown CCI high threshold -82
 select-shutdown CCI low threshold -95
 select-shutdown frequency 30
 select-shutdown frequency-limiter 5
 coverage-hole-recovery interval 5GHz 15
 coverage-hole-recovery interval 2.4GHz 15
 coverage-hole-recovery coverage-interval 5GHz 5
 coverage-hole-recovery coverage-interval 2.4GHz 5
 interference-recovery channel-hold-time 180
nx9500-6C8809(config-smart-rf-policy-test)#no interference-recovery channel-switch-delta 5GHz
nx9500-6C8809(config-smart-rf-policy-test)#no neighbor-recovery power-threshold 2.4GHz
nx9500-6C8809(config-smart-rf-policy-test)#no neighbor-recovery power-threshold 5GHz
nx9500-6C8809(config-smart-rf-policy-test)#no assignable-power 2.4GHz min
nx9500-6C8809(config-smart-rf-policy-test)#no assignable-power 5GHz max
The following example shows the Smart RF policy ‘test' settings after the ‘no' commands are executed:
 group-by floor
 sensitivity custom
