mac-address-format
Configures the format MAC addresses are filled in RADIUS request frames
Syntax
mac-address-format [middle-hyphen|no-delim|pair-colon|pair-hyphen|quad-dot]
case [lower|upper] attributes [all|username-password]
Parameters
middle-hyphen
Configures the MAC address format as AABBCC-DDEEFF
no-delim
Configures the MAC address format as AABBCCDDEEFF (without delimiters)
pair-colon
Configures the MAC address format as AA:BB:CC:DD:EE:FF
pair-hyphen
Configures the MAC address display format as AA-BB-CC-DD-EE-FF (default setting)
quad-dot
Configures the MAC address display format as AABB.CCDD.EEFF
case [lower|upper]
Indicates the case the MAC address is formatted
  • lower – Indicates MAC address is in lower case. For example, aa:bb:cc:dd:ee:ff
  • upper – Indicates MAC address is in upper case. For example, AA:BB:CC:DD:EE:FF (default setting)
attributes [all|username-password] Configures RADIUS attributes to which this MAC format is applicable
  • all – Applies to all attributes with MAC addresses such as username, password, calling-station-id, and called-station-id
  • username-password – Applies only to the username and password fields (default setting)
nx9500-6C8809(config-aaa-policy-test)#mac-address-format quad-dot case upper attributes username-password
nx9500-6C8809(config-aaa-policy-test)#show context
aaa-policy test
 authentication server 5 host 172.16.10.10 secret 0 test1 port 1
 authentication server 5 timeout 10  attempts 3
 accounting server 2 host 172.16.10.10 secret 0 test1 port 1
 accounting server 2 timeout 2 attempts 2
 authentication protocol chap
 --More--
Related Commands
no
Resets the MAC address format to default (pair-hyphen)
