monitoring-interval
Configures the interval, in seconds, at which clients are
monitored to determine if their RSSI value is below the specified handoff-threshold
value
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
monitoring-interval <1-60>
Parameters
Specifies the interval, in seconds, at which
clients are monitored to determine if their RSSI is below the specified
handoff-threshold
- <1-60> – Specify the duration from 1 - 60
seconds. The default is 5 seconds.
nx9500-6C8809(config-roaming-assist-policy-test)#monitoring-interval 40
nx9500-6C8809(config-roaming-assist-policy-test)#show context
roaming-assist-policy test
aggressiveness medium-high
handoff-count 5
detection-threshold -90
handoff-threshold -75
action log
disassoc-time 7
Related Commands
| no |
Removes the configured monitoring interval details |
