meshpoint-device
Profile Config Commands
Configures meshpoint device parameters. This feature is configurable in the profile and device configuration modes.
Syntax
meshpoint-device <MESHPOINT-NAME>
Parameters
meshpoint-device <MESHPOINT-NAME> Configures meshpoint device parameters
  • <MESHPOINT-NAME> – Specify meshpoint name.
Usage Guidelines
For VMM (Vehicular Mounted Modem) access points or other mobile devices, set the path selection method as mobile-snr-leaf in the config-meshpoint-device mode. For more information, see path-method (meshpoint-device-config).
nx9500-6C8809(config-profile-TestAP8533)#meshpoint-device test
nx9500-6C8809(config-profile-TestAP8533-meshpoint-test)#?
Mesh Point Device Mode commands:
  acs          Configure auto channel selection parameters
  exclude      Exclude neighboring Mesh Devices
  hysteresis   Configure path selection SNR hysteresis values
  monitor      Event Monitoring
  no           Negate a command or set its defaults
  path-method  Path selection method used to find a root node
  preferred    Configure preferred path parameters
  root         Set this meshpoint as root
  root-select  Root selection method parameters
  clrscr       Clears the display screen
  commit       Commit all changes made in this session
  do           Run commands from Exec mode
  end          End current mode and change to EXEC mode
  exit         End current mode and down to previous mode
  help         Description of the interactive help system
  revert       Revert changes
  service      Service Commands
  show         Show running system information
  write        Write running configuration to memory or terminal
Related Commands
no Removes a specified meshpoint
For more information on the meshpoint-device configuration parameters, see Meshpoint Policy.
