radio-resource-measurement
interface-config-radio-instance
Enables 802.11k radio resource measurement. When enabled, the radio station sends channel and neighbor reports.
The IEEE 802.11 Task Group k defined a set of specifications regarding radio resource measurements. These specifications specify the radio resources to be measured and the mechanism used to communicate measurement requests and results.
Syntax
radio-resource-measurement [attenuation-threshold <1-199>|max-entries <1-12>]
Parameters
radio-resource-measurement Enables 802.11k radio resource measurement on the radio
attenuation-threshold <1-199> Configures the neighbor attenuation threshold, considered when generating channel and neighbor reports
  • <1-199> – Specify the attenuation threshold from 1 -199. The default is 90.
max-entries <1-12> Configures the maximum number of entries to include in channel and neighbor reports
  • <1-12> – Specify a value from 1 - 12. The default is 6.
ap505-133E1C(config-profile-testap505-if-radio2)##radio-resource-measurement attenuation-threshold 150
ap505-133E1C(config-profile-testap505-if-radio2)#radio-resource-measurement max-entries 10
ap505-133E1C(config-profile-testap505-if-radio2)#show context
 interface radio2
  mesh client
  beacon period 50
  antenna-elevation 5.0
  antenna-gain 12.0
  off-channel-scan
  aggregation ampdu tx-only
  association-list global test
  aeroscout forward ip 1.23.4.56 port 300
  antenna-mode 2x2
  antenna-diversity
  assoc-response rssi-threshold -128
  bridge ssid test
  mu-mimo
  ldpc
  lock-rf-mode
  fallback-channel 104
Related Commands
no (radio-interface-config-command) Disables 802.11k radio resource measurement support
