ex3524
Adds a EX3524 switch to the network
The EX3524 series switch is a Gigabit Ethernet layer 2 switch with either 24 or 48 10/100/1000-BASE-T ports, and four SFP transceiver slots for fiber connectivity.
To enable layer 3 adoption of the logged EX3524 switch to a NOC controller, navigate to the switch‘s device configuration mode and execute the following command: controller > host > <IP/HOSTANME>.
EX3524 devices are layer 2 Gigabit Ethernet switches with either 24 or 48 10/100/1000-BASE-T ports, and four SFP transceiver slots for fiber connectivity. Each 10/100/1000 Mbps port supports both the IEEE 802.3af and IEEE 802.3at-2009 PoE standards. An EX3524 switch has an SNMP-based management agent that provides both in-band and out-of-band management access. The EX3524 switch utilizes an embedded HTTP Web agent and CLI, which in spite of being different from that of the EX3524 operating system provides EX3524 controllers PoE and port management resources.
Going forward NX7500, NX9500, and NX9600 series service platforms and WiNG VMs can discover, adopt, and partially manage EX3524 series Ethernet switches without modifying the proprietary operating system running the EX3524 switches. The WiNG service platforms utilize standardized WiNG interfaces to push configuration files to the EX3524 switches, and maintain a translation layer, understood by the EX3524 switch, for statistics retrieval.
Syntax
ex3524 <DEVICE-EX3524-MAC>
Parameters
<DEVICE-EX3524-MAC> Specifies the MAC address of a EX3524 switch
nx9500-6C8809(config)#ex3524 A1-C4-33-6D-66-07
nx9500-6C8809(config-device-A1-C4-33-6D-66-07)#?
EX35xx Device Mode commands:
  hostname         Set system's network name
  interface        Select an interface to configure
  ip               Internet Protocol (IP)
  no               Negate a command or set its defaults
  power            EX3500 Power over Ethernet Command
  remove-override  Remove configuration item override from the device (so
                   profile value takes effect)
  upgrade          Configures upgrade option for ex3500 system
  use              Set setting to use
  clrscr           Clears the display screen
  commit           Commit all changes made in this session
  do               Run commands from Exec mode
  end              End current mode and change to EXEC mode
  exit             End current mode and down to previous mode
  help             Description of the interactive help system
  revert           Revert changes
  service          Service Commands
  show             Show running system information
  write            Write running configuration to memory or terminal
Related Commands
no Removes a EX3524 switch from the network
