mint-policy-commands
The following table summarizes MiNT policy configuration commands:
Table 1. MiNT-Policy Config Mode Commands
Command Description
level Configures the MiNT routing level
lsp Enables adding of checksum to LSP messages forwarded across MiNT links
mtu Configures the global MiNT MTU
router Configures the priority for MiNT router packets (HELLO, LSP, PSNP, and EXTVLAN)
udp Configures the MiNT UDP/IP encapsulation parameters
no Negates a command or sets its default
For more information on common commands (clrscr, commit, help, revert, service, show, write, and exit), see Common Commands.
The input parameter <HOSTNAME>, wherever used in syntaxes across this chapter, cannot include an underscore (_) character. In other words, the name of a device cannot contain an underscore.
