database-client-policy global-config
Creates a database-client-policy and enters its configuration mode. The database-client-policy is only needed in deployments implementing captive-portal registration and database authentication with an onboard database. If enforcing database authentication, configure the user-name and password required to access the database on the database-client-policy.
For more information on enabling database authentication, see Example: Enabling Database Authentication.
Syntax
database-client-policy <DATABASE-CLIENT-POLICY-NAME>
Parameters
database-client-policy <DATABASE-CLIENT-POLICY-NAME> Specify the database-client-policy name. If the policy does not exist, it is created.
Once created and configured, apply this policy on the device hosting the database.
vx9000-34B78B(config)#database-client-policy DBClientPolicy
vx9000-34B78B(config-database-client-policy-DBClientPolicy)#?
Database Client Policy Mode commands:
  authentication   Database authentication
  no               Negate a command or set its defaults
  clrscr           Clears the display screen
  commit           Commit all changes made in this session
  do               Run commands from Exec mode
  end              End current mode and change to EXEC mode
  exit             End current mode and down to previous mode
  help             Description of the interactive help system
  revert           Revert changes
  service          Service Commands
  show             Show running system information
  write            Write running configuration to memory or terminal
Related Commands
no Removes an existing database-client-policy
database-policy global config Documents database policy configuration commands. If enforcing authenticated database access, use this command to enable authentication on the database and configure the username and password.
use (profile/device-config-mode-commands) Uses a database-client-policy in the VX9000's device or profile context
database Drops or repairs a database. Also provides database keyfile management capabilities. If enforcing authenticated access to the database, use this command to generate, export, import, and zerzoise the keyfile.
