class
Creates a policy map class and enters its configuration mode. The policy map class is a traffic classification upon which a policy can act.
Syntax
class <EX3500-QoS-CLASS-MAP-POLICY-NAME>
Parameters
class <EX3500-QoS-CLASS-MAP-POLICY-NAME> Specify the EX3500 QoS class map policy‘s name (should be existing and configured)
nx9500-6C8809(config-ex3500-qos-policy-map-testPolicyMap)#class dscp
nx9500-6C8809(config-ex3500-qos-policy-map-testPolicyMap-pmap-class-dscp)#?
commands:
  no       Negate a command or set its defaults
  police   Defines a policer for classified traffic
  set      Classify IP traffic
  clrscr   Clears the display screen
  commit   Commit all changes made in this session
  do       Run commands from Exec mode
  end      End current mode and change to EXEC mode
  exit     End current mode and down to previous mode
  help     Description of the interactive help system
  revert   Revert changes
  service  Service Commands
  show     Show running system information
  write    Write running configuration to memory or terminal
Related Commands
set Sets CoS value, per-hop behavior (PHB) value, and IP DSCP value in matching packets
police Configures an enforcer for classified traffic
no (ex3500-qos-policy-map) Removes this traffic classification‘s settings
