payload
Configures payload settings. The payload command sets a numerical index pattern and offset for this WIPS signature. Payload-based signatures detect patterns in the content of the file rather than attributes, such as a hash, allowing them to identify and block altered malware.
Syntax
payload <1-3> pattern <WORD> offset <0-255>
Parameters
payload <1-3>
  • <1-3> – Set the payload index from 1 - 3.
pattern <WORD>
Specifies the pattern to match: hex or string
  • <WORD> – Set the pattern name.
offset <0-255>
Specifies the payload offset to start the pattern match
  • <0-255> – Set the offset value from 0 - 255.
nx9500-6C8809(config-test-signature-test)#payload 1 pattern test offset 1
nx9500-6C8809(config-test-signature-test)#show context
 signature test
  bssid 11-22-33-44-55-66
  dst-mac 55-66-77-88-99-00
  frame-type assoc
  filter-ageout 8
Related Commands
no (wips-signature-config-mode-command)
Removes payload index and associated settings
