route-limit
      Limits the number of routes managed by
         OSPF. The maximum limit supported by the platform is the default configuration defined
         under the router-ospf context.
            - Access Points — AP410i/e, AP460i/e,
               AP505i, AP510i/e, AP560i/h, AP7522, AP7532, AP7562, AP7612, AP7632, AP7662, AP8432,
               AP8533
      Syntax
         route-limit [num-routes|reset-time|retry-count|retry-timeout]
         route-limit [num-routes <DYNAMIC-ROUTE-LIMIT>|reset-time <1-86400>|retry-count <1-32>|
retry-timeout <1-3600>] {(num-routes|reset-time|retry-count|retry-timeout)}
      Parameters
                     | num-routes <DYNAMIC-ROUTE-LIMIT> |
                     Specifies the maximum number of non self-generated LSAs this process can
                           receive
                           - <DYNAMIC-ROUTE-LIMIT> – Specify the dynamic route limit.
                     | reset-time <1-86400> |
                     Specifies the time, in seconds, after which the retry-count is reset to
                           zero
                           - <1-86400> –
                              Specify a value from 1 - 86400 seconds. The default is 360
                              seconds.
                     | retry-count <1-32> |
                     Specifies the maximum number of times adjacencies can be suppressed.
                        Each time OSPF gets into an ignore state, a counter increments. If the
                        counter exceeds the timeout configured by the retry-count parameter, OSPF
                        stays in the same ignore state. Manual intervention is required to get OSPF
                        out of the ignore state.
                           - <1-32> – Specify
                              a value from 1 - 32. The default is 5.
                     | retry-timeout <1-3600> |
                     Specifies the retry time in seconds. During this time, OSPF remains in
                        ignore state and all adjacencies are suppressed.
                           - <1-3600> –
                              Specify a value from 1 - 3600 seconds. The default is 60 seconds.
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#route-limit num-routes 10
retry-count 5 retry-timeout 60 reset-time 10
         nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context
 router ospf
  ospf enable
  network 1.2.3.0/24 area 4.5.6.7
  area 0.0.0.4
  auto-cost reference-bandwidth 1
  default-information originate metric 1 metric-type 2
  redistribute static metric-type 1
  passive vlan1
  route-limit num-routes 10 retry-count 5 retry-timeout 60 reset-time 10
  ip default-gateway priority 1
