application
purview-application-group
Adds an application definition to this Purview application group. You can add a system-provided or customized (user-defined) application.
Syntax
application <PURVIEW-APP-NAME>
Parameters
application <PURVIEW-APP-NAME> Configures the application to be added to this application group
  • <PURVIEW-APP-NAME> – Provide the application name (should be available as an option in the system). A maximum of eight (8) applications can be added to a group.
    Note: The Purview™ libDPI engine recognizes 36 app categories with 2406 applications. If the desired application is not available as an option, use the application command to add it.
To view all applications supported by the Purview ™ libDPI engine, use [TAB], as shown in the following example:
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#application[TAB]
Display all 365 possibilities? (y or n)
163_com                           1Fichier
24x7_Media                        2K_Games
360_Software                      360buy
4chan                             4shared
5Dimes                            8Track
9gag                              A_Feed
AB_Tutor                          Abacast
--More--
Select the desired application from the list displayed, as shown in the following examples:
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#application Ali[TAB]
Alibaba      Alibaba_Ads  AliExpress   Alipay
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#application Alipay
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#application Alibaba
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#application AliExpress
nx9500-6C8809(config-purview-app-group-PurvAppGrp)#show context
application-group PurvAppGrp
 application Alipay
 application Alibaba
Related Commands
no Removes a specified application from this application group
