logging
Enables logging for a specified route map. When enabled, this option logs events generated by the enforcement of route-maps. This option is disabled by default.
Syntax
logging
Parameters
None
nx9500-6C8809(config-routing-policy-testpolicy)#logging
nx9500-6C8809(config-routing-policy-testpolicy)#show context
routing-policy testpolicy
 logging
Related Commands
no (routing-policy-config-mode-command) Disables route map logging
