dhcp-relay-incoming
interface-config-vlan-instance
Allows an onboard DHCP server to respond to relayed DHCP packets. This option is disabled by default.
Syntax
dhcp-relay-incoming
Parameters
None
nx9500-6C8809(config-profile-default-rfs4000-if-vlan8)#dhcp-relay-incoming
nx9500-6C8809(config-profile-default-rfs4000-if-vlan8)#show context
 interface vlan8
  description "This VLAN interface is configured for the Sales Team"
  crypto map map1
  dhcp-relay-incoming
Related Commands
no Disables or reverts interface VLAN settings to their default
