deny (bgp-as-path-list)
Creates and configures a deny as-path-list rule. The deny rule specifies a regular expression to match. This regular expression, is matched against the BGP AS paths contained in routing updates. AS paths matching the provided string are filtered and a deny action is applied.
Syntax
deny as-path <REG-EXP>
Parameters
deny as-path <REG-EXP> Configures a match criteria (regular expression).
  • <REG-EXP> – Specify the regular expression to match (should not exceed 64 characters and should be unique to the AS path list rule)
Regular expressions are treated as a ‘ASCII string‘ and not as a sequence of numbers. Create a regular expression ideally suited to filter the required AS paths.
Usage Guidelines
The following table lists some of the characters used in forming regular expressions:
Table 1.
Character to use Description
^ Indicates the start of a string
$ Indicates the end of a string
_ (underscore) Indicates a comma, left brace, right brace, start and end of an input string, or a space. For example, “_ _”.
nx9500-6C8809(config-bgp-as-path-list-test)#deny as-path ^100$
nx9500-6C8809(config-bgp-as-path-list-test)#show context
bgp as-path-list test
 deny as-path ^100$
Related Commands
no (bgp-as-path-list) Removes the specified deny, as-path rule
