ipv6
Configures IPv6 components on this firewall policy
Syntax
ipv6 [dos|duplicate-options|firewall|option|rewrite-flow-label|routing-type|
strict-ext-hdr-check|unknown-options]
ipv6 dos {hop-limit-zero|multicast-icmpv6|tcp-intercept-mobility} [drop-only|
log-and-drop|log-only]
ipv6 [duplicate-options|routing-type [one|two]|strict-ext-hdr-check|unknown-options]
[drop-only|log-and-drop|log-only]
ipv6 option {endpoint-identification|network-service-access-point|router-alert|
strict-hao-opt-alert|strict-padding} [drop-only|log-and-drop|log-only]
ipv6 [firewall enable|rewrite-flow-label]
Parameters
dos Identifies IPv6 events as DoS events
hop-limit-zero Optional. Enables checking of IPv6 hop limit field. If the IPv6 hop limit field is ZERO (0) it is considered as attack. This option is enabled by default.
multicast-icmpv6 Optional. Enables detection of multicast ICMPv6 traffic as attack. This option is applicable only to ICMPv6 Echo request or reply packets. This option is enabled by default.
tcp-intercept-mobility Optional. Enables detection of IPv6 TCP packets with mobility option "HAO(Home-Address-Option)" or "RH(Routing Header) type two". When enabled, this option also detects the “don't generate TCP syn cookies” for such packets. This option is enabled by default.
drop-only This parameter is common to all of the above keywords.
Drops all packets. Drops the specified packet type (hop-limit-zero, multicast-icmpv6, and tcp-intercept-mobility).
log-and-drop Logs the event and drops the packet. Drops the specified packet type (hop-limit-zero, multicast-icmpv6, and tcp-intercept-mobility) and logs an event.
log-only Logs the event only, the packet is not dropped. Does not drop the specified packet type (hop-limit-zero, multicast-icmpv6, and tcp-intercept-mobility). But, an event is logged.
log-level If selecting the “log-and-drop” and “log-only” action type, specify the log level. The options are:
  • <0-7> – Sets the numeric logging level
  • alerts – Numerical severity 1. Indicates a condition where immediate action is required
  • critical – Numerical severity 2. Indicates a critical condition
  • debugging – Numerical severity 7. Debugging messages
  • emergencies – Numerical severity 0. System is unusable
  • errors – Numerical severity 3. Indicates an error condition
  • informational – Numerical severity 6. Indicates a informational condition
  • notifications – Numerical severity 5. Indicates a normal but significant condition
  • warnings – Numerical severity 4. Indicates a warning condition. This is the default setting.
duplicate-options Enables handling of duplicate options in hop-by-hop and destination option extension headers. This configuration excludes HAO handling. This option is enabled by default.
routing-type [one|two] Enables checking of the following IPv6 routing types:
  • one – Routing Type 1(Nimrod routing). This option is disabled by default.
  • two – Routing Type 2(Mobile IP). This option is disabled by default.
strict-ext-hdr-check Enables strict checking for out of order and number of occurrences of extension header. This option is enabled by default.
unknown-options Enables handling unknown options in hop-by-hop and destination option extension headers. This option is enabled by default.
Drops all packets. Drops the packet if matching any of the above specified types.
log-and-drop Logs the event and drops the packet. Drops the packet, if matching any of the above specified types, and logs an event.
log-only Logs the event only, the packet is not dropped. Does not drop the packet, if matching any of the above specified types. But an event is logged.
option Enables checking for the following ipv6 extension header options:
  • End point identification option (disabled by default)
  • Network service access point address option (disabled by default)
  • Router alert option (disabled by default)
  • Home address option in destination option extension header (enabled by default)
  • Pad1 and PadN options validating (enabled by default)
All of these are optional parameters. If no option is specified, the system enables checks as per the default values.
Drops all packets. Drops the packet if matching any of the above specified “option” types.
log-and-drop Logs the event and drops the packet. Drops the packet, if matching any of the above specified “option” types, and logs an event.
log-only Logs the event only, the packet is not dropped. Does not drop the packet, if matching any of the above specified “option” types. But an event is logged.
firewall enable Enables IPv6 firewall. This option is enabled by default.
rewrite-flow-label Rewrites the IPv6 flow label field of every packet. This option is disabled by default.
nx9500-6C8809(config-fw-policy-testFW)#ipv6 dos hop-limit-zero drop-only
nx9500-6C8809(config-fw-policy-testFW)#ipv6 routing-type two log-and-drop log-level warnings
nx9500-6C8809(config-fw-policy-testFW)#show context
firewall-policy testFW
 ip dos fraggle drop-only
 ip dos tcp-sequence-past-window drop-only
 ip dos tcp-max-incomplete high 600
 ip dos tcp-max-incomplete low 60
 ip-mac conflict drop-only
 ip-mac routing conflict log-and-drop log-level notifications
 flow timeout icmp 16000
 flow timeout udp 10000
 flow timeout tcp established 1500
 flow timeout other 16000
 dhcp-offer-convert
 alg facetime
 dns-snoop entry-timeout 1200
Related Commands
no Resets this firewall policy‘s IPv6 components
