ip-access-list-stats
Displays IP access list statistics
This command is not available in the USER EXEC Mode.
Syntax
show ip-access-list-stats {<IP-ACCESS-LIST-NAME>|detail|on}
show ip-access-list stats {<IP-ACCESS-LIST-NAME>|detail <IP-ACCESS-LIST-NAME>}
{(on <DEVICE-NAME>)}
Parameters
ip-access-list-stats Displays IP access list statistics
<IP-ACCESS-LIST- NAME> Optional. Displays statistics for a specified IP access list. Specify the IP access list name.
detail <IP-ACCESS -LIST-NAME> Optional. Displays detailed statistics for a specified IP access list. Specify the IP access list name.
on <DEVICE-NAME> The following keyword is recursive and common to the ‘IP-ACCESS-LIST-NAME' parameter:
  • on <DEVICE-NAME> – Optional. Displays all or a specified IP access list statistics on a specified device
    • <DEVICE-NAME> – Specify the name of the AP, wireless controller, or service platform.
nx9500-6C8809(config)#show ip-access-list stats
IP Access-list: # Restrict Management ACL #
  permit tcp any any eq ftp rule-precedence 1        Hitcount: 0
  permit tcp any any eq www rule-precedence 2        Hitcount: 4
  permit tcp any any eq ssh rule-precedence 3        Hitcount: 448
  permit tcp any any eq https rule-precedence 4        Hitcount: 0
  permit udp any any eq snmp rule-precedence 5        Hitcount: 0
  permit tcp any any eq telnet rule-precedence 6        Hitcount: 4
The following example displays the ‘auto-tunnel-acl‘ IP ACL configuration:
nx9500-6C8809(config)#ip access-list auto-tunnel-acl
nx9500-6C8809(config-ip-acl-auto-tunnel-acl)#show context
permit ip host 200.200.200.99 30.30.30.1/24 rule-precedence 2
permit ip host 200.200.200.99 any rule-precedence 3
The following example dispalys the statistics for the ‘auto-tunnel-acl‘ ACL:
nx9500-6C8809#show ip-access-list stats
IP Access-list: auto-tunnel-acl
  permit ip host 200.200.200.99 30.30.30.1/24 rule-precedence 2        Hitcount: 0
  permit ip host 200.200.200.99 any rule-precedence 3        Hitcount: 0
nx9500-6C8809#
