configuration-persistence
Profile Config Commands
Enables configuration persistence across reloads. This option is enabled by default.
Syntax
configuration-persistence {auto|secure}
Parameters
auto Optional. Assigns default value based on the device type
secure Optional. Ensures parts of a file that contain security information are not written during a reload
nx9500-6C8809(config-profile-default-ap8533)#configuration-persistence secure
nx9500-6C8809(config-profile-default-ap8533)#show context
profile ap8533 default-ap8533
 bridge vlan 1
  no edge-vlan
  ip igmp snooping
  no ip igmp snooping unknown-multicast-fwd
  no ip igmp snooping mrouter learn pim-dvmrp
  autoinstall configuration
 autoinstall firmware
 cluster name cluster1
 cluster member ip 1.2.3.4 level 2
 cluster member ip 172.16.10.3
 cluster member vlan 4094
 cluster handle-stp
 cluster force-configured-state
  holdtime 1000
  timer 900
Related Commands
no Disables automatic write up of startup configuration file
