auto-cost
Configures the reference bandwidth in terms of megabits per second. Specifying the reference bandwidth allows you to control the default metrics for an interface, which is calculated by OSPF.
The formula used to calculate default metrics is: ref-bw divided by the bandwidth.
Use the no → auto-cost → reference-bandwidth command to configure default metrics calculation based on interface type.
Syntax
auto-cost reference-bandwidth <1-4294967>
Parameters
reference-bandwidth <1-4294967> Defines the reference bandwidth in Mbps
  • <1-4294967> – Specify the reference bandwidth value from 1 - 4294967.
nx9500-6C8809(config-profile default-ap8533-router-ospf)#auto-cost reference-bandwidth 1
Ensure that auto-cost reference-bandwidth is configured uniformly on all routers
nx9500-6C8809(config-profile default-ap8533-router-ospf)#show context router ospf
  area 0.0.0.4
Related Commands
no (router-mode-config-command) Removes auto-cost reference bandwidth settings
