no (routing-policy-config-mode-command)
Removes this Routing policy settings or reverts them to default values
Syntax
no [apply-to-local-packets|logging|route-map|use]
Parameters
no <PARAMETERS>
no <PARAMETERS> Removes this routing policy settings or reverts them to default values, based on the parameters passed.
Usage Guidelines
The no command negates any command associated with it. Wherever required, use the same parameters associated with the command getting negated.
The following example shows the routing policy ‘testpolicy‘ settings before the ‘no‘ commands are executed:
nx9500-6C8809(config-routing-policy-testpolicy)#show context
routing-policy testpolicy
 logging
 route-map 1
  match incoming-interface pppoe1
  default-next-hop wwan1  mark ip dscp 7
nx9500-6C8809(config-routing-policy-testpolicy)#no logging
nx9500-6C8809(config-routing-policy-testpolicy)#no route-map 1
nx9500-6C8809(config-routing-policy-testpolicy)#no apply-to-local-packets
The following example shows the routing policy ‘testpolicy‘ settings after the ‘no‘ commands are executed:
